Running out of memory (#3027)
Attached is simple model of a 1"x12" coil spring created in SharkFX V7. I am trying to create 2 views from a plan view of a front and right auxiliary view, but before it can finish I am running out of memory and the program crashes. running XP64 with 8 gig's of memory. Program crashes at about 1.7 gigs.
100X12 coil spring.zip
(1,473kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
David Gross Dmg Design Colgate, Wi.
Originally Posted by: David Gross Program crashes at about 1.7 gigs.
Shark/VC are [URL="http://forum.punchcad.com/showthread.php?t=2816"]currently 32 bit applications[/URL] which therefore cannot access more than 2gb even under 64 bit operating systems.
Norb.
Originally Posted by: David Gross Tim Attached is simple model of a 1"x12" coil spring created in SharkFX V7. I am trying to create 2 views from a plan view of a front and right auxiliary view, but before it can finish I am running out of memory and the program crashes. running XP64 with 8 gig's of memory. Program crashes at about 1.7 gigs. Thanks
Hi David,
I did a four view aok with V7 of this file. Are you using your own Layout or did you pick one from the list?
Guys It maxed memory and hung on Vista 32 bit. Std D Size Model to sheet Precise lines... Jason
Tim I am using a top view sheet that I created with V7 and then making the auxiliary view off of that.
Tim Is this repeating for you because I use 4 to 20 springs in different dia.'s and lengths in every project I do and this repeats for me every time. Thanks
Hello is there any one out there.
Can you simplify the springs geometry in any way, or is there something hidden that consumes memory? I have only had this issue with files that are nearing the Gigabyte level.
