2D Drafting
join curve - tolerance? (#2416)
Hello,
It's possible reduce the tolerance for a correct or preserve geometry with the "join curve" tool?
Thanks.
Antoine
(33kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: la mouche Hello, It's possible reduce the tolerance for a correct or preserve geometry with the "join curve" tool? Thanks. Antoine
Hi Antoine,
I suspect one of your two curves is a spline. If you join two lines, you will get a polyline that preserves the discontinuity. If you join anything else, it will make single C2 continuous curve. When you have a sharp discontinuity as in your image, your going to get deviations at the join point as making the resulting curve C2 is the priority.
thank you Tim, I no longer have model, but I send you a sample as soon as possible.
2D Drafting
