Hi Tim, I would like to work ... seriously ... and be productive ... What version of [COLOR="Red"]SharkFX[/COLOR] least buggy? please. I would also like [COLOR="Red"]the link[/COLOR] to the healthy version Thanks Antoine
Antoine, in theory 968 (?)
omgaaaddd nooooo!!!!!
see
http://forum.punchcad.com/showthread.php?t=3956 stop theory...
i want stability :mad:
thanks JF :)
Antoine
????? I'm serious, and I'd like an answer to my question please. Thanks. Antoine
Antoine, I have found version 7 build 978 to be very stable. I keep it on my system, maybe Tim can mail you a download link. Regards, Orlando
Antoine, I like version 7 build 978 . This is from June, it is not the latest, I think Tim made a typo or so, but I keep it on my system. Maybe Tim can give you a download link. regards, Orlando
No, [COLOR="SeaGreen"]978 [/COLOR] , I am telling you the number is probably wrong but that is what it says in "About..."
Weird, maybe only Tim have an answer for this!
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
Originally Posted by: orlandosardaro No, [COLOR="SeaGreen"]978 [/COLOR] , I am telling you the number is probably wrong but that is what it says in "About..."
is this build for viacad or shark?
as far as i know, the last stable release for shark is 968, and beside the disappearing menu and damaged files saved as sp1 this version works pretty solid, (without considering all the improvements that shall be made, like symbols, model to sheet, 64 bits..... etc).
I am aware that Antoine have his damaged file on this version, i got one once, and it was saved as SP1, so I learn to avoid the next things: save as sp1 version and compact command, don use it.
Luis G.
Quote: I am aware that Antoine have his damaged file on this version, i got one once, and it was saved as SP1, so I learn to avoid the next things: save as sp1 version and compact command, don use it.
I do not use this.
When it crashes, it may be that [COLOR="Red"]I save to another drive[/COLOR] on my Mac.
Tim? Is this perhaps a track for your research on this bug?
Antoine
