Suggestions
Sweep/Extrude By Example (#5163)
Thanks: 73 times Was thanked: 86 time(s) in 55 post(s)
Maybe this would be a PowerPack or just a new feature, but, this can be quite useful for those designing ribs/frames in aircraft, submarines, and ship hulls. Assumptions: - the design, whatever length, has 50-200 stations - the stations may or may not be of different sizes within one or more zones, say up to 15 - each station has stiffening - each stiffener has a web and a flange (or, could just be flatbar stiffened - each web is formed by a profile of curves with an associated surface that will be swept - each flange is formed by a profile of curves with an associated surface that will be swept This has to be done 50-200 times OR -- ONE pattern per zone could be defined by the user, from a profile pattern/template -- the sweep command is initiated -- the surface to be swept is selected -- the station curves are selected (singly, or in a lasso/right select, but the app should deduce the ascending direction or ask for it) Such a feature would remove between 4 and 8 clicks per sweep. Imagine that 50 sweeps require 4 clicks. Imagine 8 clicks Now, that's just for transverse framing, swept along stations in a hull or fuselage. Now, imagine doing that for shell longitudinal stiffeners, but now, you have 4 decks, or more, and you have 4 or 5 shell longitudinal stiffeners per deck, or 16-20 of them in 4 decks. Again, 4 to 8 clicks (not even counting angular adjusttments involving switching into and out of Gripper angles set per user-selected origins). Now, you have to deck longitudinals. Now, you have to do deck transverses. A "Sweep-by-example" would expand on "it thinks while you draw"> This would remove a lot of "session fatigue" and likely dramatically boost workflow and productivity. WITHOUT the user needing to write macros or slog away at mind-numbing tedium of doing this when multiple models for studies need to be created.
Suggestions
