NorthridgeFab
#1 Posted : Friday, February 15, 2013 9:55:07 PM(UTC)
NorthridgeFab
Currently, if I have a DXF or DWG file on say my desktop and I double click it; it will not open with ViaCAD. I have to open ViaCAD then open the file. Is it possible to set it where when I double click on the file with you start ViaCAD and open the file? BTW, I am using a mac.
#2 Posted : Saturday, February 16, 2013 9:22:50 AM(UTC)
- Right click, then get info (or cmnd+i),
- click "open with" popup menu, if viacad is not listed click "other" option,
- on new window on activate pop up select all applications option
- navigate to select via-cad, click "add"
- before close info window, click on "change all" button to make viacad default app to open this kind of files
Hope this Help
Luis G.
MacOSX Sonoma 14.7.1
NorthridgeFab
#3 Posted : Thursday, February 21, 2013 8:46:14 AM(UTC)
NorthridgeFab
When I do this it does open ViaCAD, but with a blank sheet, not the dxf.
#4 Posted : Thursday, February 21, 2013 10:04:17 AM(UTC)
Your right, confirmed here, should be a bug, in the past this used works fine, meanwhile drag and drop your file in to that blank sheet will import the dxf. (this is my normal way to do it, thats the reason I didn't notice that bug.)
