bradcan
#1 Posted : Monday, September 20, 2010 4:29:10 PM(UTC)
bradcan
A couple of things seem to have failed since installing the upgrade to build 853!
I used to be able to flip the work plane with a hot key! Sadly I seem to have forgotten the key sequence. Or it just doesn't work any more. :confused: Neither can I find the documentation or tutorial which gave me the clue to this handy feature. Could somebody post a sticky in tutorials or add the keys to the reference card.
I can no longer do any cross hatching! When I select 'Cross Hatch...' from the 'Pen' menu the dialog box title is: 'Definition file xhatch.ini not found' and the dialog is empty. Does anybody know where is and what should be in xhatch.ini
TIA
#2 Posted : Monday, September 20, 2010 5:32:37 PM(UTC)
TIA
Hi Brad
The key that flips the workplane is the c key after you click at a snap point like endpoint etc. tapping the c key cycles the workplane.
bradcan
#3 Posted : Tuesday, September 21, 2010 6:00:41 AM(UTC)
bradcan
Thanks Jason, work plane flip still works. :) It must be the onset of senile decay. :eek:
