matze134
#1 Posted : Monday, January 15, 2024 5:34:19 AM(UTC)
matze134
Hello,
I have a problem with a file I saved in ViaCAD 9.0 at the last session.
When I try to open it, there appeares a message, the file is damaged.
"This file is damaged! Cannot read into application.
File position: 1632251
File size: 1632251
Filename: xyz.vc3"
Is there a chance to rescue the file?
I opened the file in a texteditor. At the end there is the Word "SUCCESS".
Could anybody help me? It took a few hours to create the file.
matze134 attached the following image(s):
Screenshot 2024-01-15 11.48.05.png (8kb) downloaded 1 time(s).
Birger
#2 Posted : Tuesday, January 16, 2024 11:44:29 PM(UTC)
Birger
Norway
Was thanked: 16 time(s) in 5 post(s)
Sorry for the negative message, but this is an issue with SharkCAD also. File is probably lost.
A tip is to regularly do incremental save a copy under new name on any file you work on as well as have the backup feature turned on. E.g. add date and version to your filename like "filename 240112-1..." and so on.
A "benefit" with this software is that you thus end up with GB of data for files. For you own safety also save a few of the various file versions to your backup..
