#1 Posted : Friday, May 5, 2023 8:57:43 AM(UTC)
The Release Notes:
http://forums.punchcad.c...ts&t=10933#post41851
Change Log for 1629
1. Corrected instance of file corruption when reading in decals from V12
2. Corrected view clipping instance in ortho and perspective views
3. Corrected unit conversion issue with camera focal length
4. Added a prompt message when calculating mass properties without material assignments
My own positive impressions of version 14
  • MTS now works better. Hidden lines are correctly displayed even in larger assemblies in the isometric view.
  • Dynamic rotation is now smoother, meaning the OpenGL support has been improved.
Edited by user Friday, May 5, 2023 9:07:15 AM(UTC)  | Reason: Not specified
specktech on 5/8/2023(UTC)
