L. Banasky
#1 Posted : Wednesday, March 1, 2023 1:48:32 PM(UTC)
L. Banasky
Shark just would not open, downloaded the latest version, which was also
difficult because of security issues.
Will not load, as per the included error, you can click "Ignore" a
hundred times for different files, nothing works.
Windows Error.jpg (169kb) downloaded 0 time(s).
#2 Posted : Wednesday, March 1, 2023 2:18:59 PM(UTC)
Larry,
It looks like a write error. Do you have permissions for E drive?
L. Banasky
#3 Posted : Wednesday, March 1, 2023 3:03:49 PM(UTC)
L. Banasky
Thanks Tim,
I've been using Shark on E:/ for years, yesterday indicated shortcut can no longer find Shark.
Maybe I should try installing on C;/
Larry,
Update: Installed fine on C:/, strange all other programs on E:/ work fine.
I might have to do the unthinkable for Shark, Switch over to the Mac.
Edited by user Wednesday, March 1, 2023 3:46:46 PM(UTC)  | Reason: Not specified
#4 Posted : Friday, March 3, 2023 5:33:05 AM(UTC)
No. Please do this not. then you need for every new Mac-Version a new Shark-Version.
In Windows also you can use all older Versions and 32 bit Software.
GARLIC on 3/3/2023(UTC), L. Banasky on 3/3/2023(UTC)
L. Banasky
#5 Posted : Friday, March 3, 2023 8:24:43 AM(UTC)
L. Banasky
Thanks MP,
Must have been a nightmare that I had switching to a Mac.
