VIACAD 14 Issues (MacOS)
Thanks: 23 times Was thanked: 8 time(s) in 6 post(s)
I ll use this thread to post issues I find. 1. PowerPack "Reduce Triangles" crashes. I may be using it wrong! (Im working on a fairly simple mesh imported from an STL) <code>
Translated Report (Full Report Below) Process: ViaCAD 14 [64270] Path: /Applications/ViaCAD 14.app/Contents/MacOS/ViaCAD 14 Identifier: com.encore.viacad14esd Version: 14.0.0 (1616) Code Type: X86-64 (Translated) Parent Process: launchd [1] User ID: 501 Date/Time: 2023-01-27 23:11:04.4384 -0400 OS Version: macOS 12.3 (21E230) Report Version: 12 Anonymous UUID: AA0CC10D-4B8A-785D-3EC5-E504C3FCF3DA Sleep/Wake UUID: 4827D1E8-6610-4752-85EE-D14001A27026 Time Awake Since Boot: 3900000 seconds Time Since Wake: 5238 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000068 Exception Codes: 0x0000000000000001, 0x0000000000000068 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11 Terminating Process: exc handler [64270] VM Region Info: 0x68 is not in any region. Bytes before following region: 4342833048 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL UNUSED SPACE AT START ---> __TEXT 102da6000-107c5e000 [ 78.7M] r-x/r-x SM=COW ...cOS/ViaCAD 14 Application Specific Information: Performing @selector(pushButtonChanged:) from sender NSButton 0x7f94fa90fef0 Kernel Triage: VM - pmap_enter failed with resource shortage VM - pmap_enter failed with resource shortage VM - pmap_enter failed with resource shortage VM - pmap_enter failed with resource shortage VM - pmap_enter failed with resource shortage </code>
1 user thanked ctkjose for this useful post.
That's always been the case. It's never worked right.
Can you post or private email the file? Thanks Tim
