custom 3d print infill extrusion methods
Viacad 9 I want to draw some custom infilled areas for 3d printed objects. (Rather than letting the slicer generate them) First thing that comes to mind is something like extruding a cross hatched area... but I don't think that is possible. I can do it my drawing one element of the infill (a triangle ,for example) amd then using "duplicates" to disperse them, then extrude and "trim" solid. It's workable, is there an even easier way?
Was thanked: 27 time(s) in 18 post(s)
Create a solid hatching, arbitrarily something like a grid with 1mm thick lines at 3mm spacing, so a linear array of plates added to a copy rotated 90 degrees or similar. Make a copy of the outer shell of your model, which has got to be a filled solid, and intersect it with the grid array to provide the fill, then add that to a shell of the outer surface, while your original .stl, .obj, .3mf, whatever is probably solid fill, so you'll have to add that to your workflow. Bear in mind that the standard infill also supports overhangs of the upper surface, if your custom fill doesn't accommodate that, you might get sag failures.
Edited by user Tuesday, November 15, 2022 6:50:18 PM(UTC)
Custom solid infill v7.sfx
(1,723kb) downloaded 2 time(s). 2murray attached the following image(s):
(246kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked 2murray for this useful post.
