Import/Export
Exporting SharkCAD to Solidworks
Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
Does anyone know the best format to use to export a SharkCAD file to SolidWorks?
Thanks: 235 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: Albatrossflyer Does anyone know the best format to use to export a SharkCAD file to SolidWorks?
I use .STP export
The history is lost but all the 3D data are correct, most of the time.
Edited by user Wednesday, May 11, 2022 3:40:20 AM(UTC)
Thanks: 353 times Was thanked: 258 time(s) in 170 post(s)
The best format for exporting Solids is always the ACIS SAT format because the STEP-Format splitting the cylinder-surfaces in 2 parts. If this splitting not so important for you is the STEP-Sormat the best way, because the ACIS SAT-Format keeping no Layers.
Thanks: 1 times Was thanked: 10 time(s) in 6 post(s)
I have transfered hundred of files to Solidworks. For quick import I use parasolid , which is the base of solidworks. I use parasolid V 11 due to best experience. I only use parasolid for large assemblies with many parts. Step import into Solidworks lasts very long with lot of parts, but you rarely need to repair these. I usually repair all parts in Solidworks before transferring to clients.
1 user thanked gebhardt for this useful post.
Import/Export
