in need of tutoring/training specifically in primitives and 3d
Anyone here do training? I'm struggling with primitives. I'm struggling with push/pull. I could go on. I need to design square and rectangular tubing frames. The best function I've found is primitives. But I'm open to any way that is less painful. Some of the issues I have are: block primitive 3 point diagonals- it doesn't usually place the block at the point I chose. When I type a number, the part extrudes often in the negative direction. But not always. Screen share and/or phone? Thanks, Timothy
Hi Timothy
Have you tried the pipe tool? Select centerline and pick either circle or rectangular section and specify wall thickness.
Edited by user Thursday, December 12, 2019 11:54:05 AM(UTC)
(770kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
Thanks for the suggestion Tim. But I don't think that's gonna work for me (and I can't find it). I want to use an edge rather than center.
Thanks: 319 times Was thanked: 192 time(s) in 136 post(s)
Originally Posted by: sainttimothy Thanks for the suggestion Tim. But I don't think that's gonna work for me (and I can't find it). I want to use an edge rather than center.
if you need a cutlist you need to make every single part from the frame also with the miter. For symmetrical parts you can use later the mirror tool. Maybe i make a video how it works, but you need alot tools for this like the extrude tool and some Tools for cutting the miter (place a infinite plane in the right position and split the solid and delete the Sektion.
Edited by user Friday, December 13, 2019 5:22:01 PM(UTC)
