Gallery
Lab Equipment - Modeled in Shark - Rendered in Modo (#4867)
All parts modeled from sketches using Shark v7. Exported to OBJ, textured and rendered in MODO 701.
Gorgeous render, gotta say. Tech pedantry: the two front inlet/outlets on the RH side of the piece obscure the top front (in the pic) screw, which is going to make it fussy to access.
Actually the center plastic part has a filtering membrane inside it, the glass gizmos are pressed against the middle plastic part with a clamp. For the sake of a pretty picture, we left off the ugly clamp. :)
Makes sense. Tech pedantry 2: do the four ports angled to the front make entry to where the fluid is? It looks as if the fluid ought to be visible in them.
The device is a chamber within a chamber. Fluid is added from the top opening, which goes into an inner chamber. The two smaller openings access the outer chamber and are for additional fluids / gases / heat to be introduced to affect the osmosis process.
beau travail! bravo! Antoine
Interesting. What's it testing? Solutions or membranes?
Originally Posted by: zumer Interesting. What's it testing? Solutions or membranes?
That, I don't know :) but here is the client's website:
http://www.pion-inc.com/instruments/udiss-profiler
Thanks: 230 times Was thanked: 182 time(s) in 110 post(s)
Gallery
