joev
#1 Posted : Monday, November 11, 2013 12:31:35 PM(UTC)
joev
All parts modeled from sketches using Shark v7. Exported to OBJ, textured and rendered in MODO 701.
UserPostedImage
zumer
#2 Posted : Monday, November 11, 2013 2:22:36 PM(UTC)
zumer
Gorgeous render, gotta say. Tech pedantry: the two front inlet/outlets on the RH side of the piece obscure the top front (in the pic) screw, which is going to make it fussy to access.
joev
#3 Posted : Monday, November 11, 2013 3:13:43 PM(UTC)
joev
Actually the center plastic part has a filtering membrane inside it, the glass gizmos are pressed against the middle plastic part with a clamp. For the sake of a pretty picture, we left off the ugly clamp. :)
zumer
#4 Posted : Monday, November 11, 2013 11:15:43 PM(UTC)
zumer
Makes sense. Tech pedantry 2: do the four ports angled to the front make entry to where the fluid is? It looks as if the fluid ought to be visible in them.
joev
#5 Posted : Tuesday, November 12, 2013 12:05:38 AM(UTC)
joev
The device is a chamber within a chamber. Fluid is added from the top opening, which goes into an inner chamber. The two smaller openings access the outer chamber and are for additional fluids / gases / heat to be introduced to affect the osmosis process.
la mouche
#6 Posted : Tuesday, November 12, 2013 3:01:17 AM(UTC)
la mouche
beau travail! bravo!
Antoine
zumer
#7 Posted : Tuesday, November 12, 2013 5:13:14 AM(UTC)
zumer
Interesting. What's it testing? Solutions or membranes?
joev
#8 Posted : Tuesday, November 12, 2013 10:10:14 AM(UTC)
joev
That, I don't know :) but here is the client's website:
http://www.pion-inc.com/instruments/udiss-profiler
#9 Posted : Tuesday, November 12, 2013 6:09:01 PM(UTC)
Was thanked: 182 time(s) in 110 post(s)
Very nice work !
JL
Guest (10)
