joev
#1 Posted : Monday, August 6, 2012 6:37:41 PM(UTC)
joev
Had my computer crash and with it, took my records of my Shark authorization and serial number codes. After reinstalling Shark v7 I now need to reactivate it.
I emailed support but have not heard back. I sure could use those codes sooner rather than later.
I would suggest Punch should set up user accounts like Luxology, a user can login, download what software they had purchased, any updates and generate license codes as needed.
#2 Posted : Monday, August 6, 2012 9:50:33 PM(UTC)
as far as i know, with your serial and the registration node shark's registration process gives you, you can generate the authorization/activation code online, no need to email them unless you went run out of the 5 chances that you have to do it.
Had you try to go through registration process?
MacOSX Sonoma 14.7.1
#3 Posted : Tuesday, August 7, 2012 7:44:15 PM(UTC)
Hi Joe
Did you use Support@evo-soft.net or another email address?
joev
#4 Posted : Thursday, August 9, 2012 8:24:53 PM(UTC)
joev
I did receive the codes. The issue was I lost both the Serial number and Product code, so I could not use the Authorization process. Once I was sent the info, I was able to generate the auth code. Like always, the crash occurred on a Friday and I had projects to work on over the weekend.
I would still like to see a better process of accessing updates and purchased software similar to what Lux does. I have version 7 of Shark but I do not see any info on the web site if an upgrade is available and at what cost.
Thanks to Todd from Encore for sending me the info!
