joe.johnson@jtsrestaurant
#1 Posted : Friday, May 6, 2011 12:18:48 PM(UTC)
I need to know how to change the size of the ballons that are created from the Attribut /BOM window when you press 'create balloons'. They are way to small to see
NickB
#2 Posted : Friday, May 6, 2011 1:26:54 PM(UTC)
NickB
Select the balloon, or all balloons, then in the Inspector (Windows menu), go to Object: Properties / Data. There you can change the frame type, its width / diameter, text size etc.
Shark FX 9 build 1143
OS X 9.5
matter.cc
