First time on the site. Thanks for letting me participate. I have been trying out the "Path Duplicate" and it does not seem to do/work as I imagined or as the manual/or help would seem to indicate. Any advice appreciated. ps ViaCAD (what a great step up from Amapi7.52!)
Here's a quicktime movie showing a simple translate along path. You may need to post more info, if this does not help.
http://www.csi-concepts.com/Demo/TranslateAlongPath.mov Key items:
--the origin is the point that is translated from the part to on the path.
--the alignment vector aligns the part relative to the curve tangent.
Hope this helps!
Thanks. I wanted to do the exercise using a sphere--and I worked out that these same proceedure had to be followed. And it worked! Am I correct that the method is not "adequately" described in the manual perhaps?
