Custom template! (#3069)
Tim.....Can we customize the Model to Sheet template. Our registration name is automatically insert in the pattern...but can we add-on something else..some repetitive things. THX.
Originally Posted by: Jean-Francois Jacques Tim.....Can we customize the Model to Sheet template. Our registration name is automatically insert in the pattern...but can we add-on something else..some repetitive things. THX.
Hi JF
You can put a copy of your template in the folder and select it when you do model to sheet, so you can customize the way you like.
Yes in the templates folder... with .sfx extension...not .srk! (what is .srk?) Thanks.
Originally Posted by: Jean-Francois Jacques Yes in the templates folder... with .sfx extension...not .srk! (what is .srk?) Thanks.
HI JF
.vc2 is ViaCAD 2d
.vc3 is ViaCAD 2d/3d
.vcp is ViaCAD Pro
.slt is Shark LT
.srk is Shark
.sfx is Shark FX
The programs in the Punchcad family can open each others files...
