brianwhitecc
#1 Posted : Tuesday, April 3, 2007 11:01:26 AM(UTC)
brianwhitecc
Can the Bezier tool in ViaCad do corner points?
bw
#2 Posted : Tuesday, April 3, 2007 3:32:53 PM(UTC)
Hi Brian,
Sorry, no corner points. Each curve must be tangent/G1 continuous. It's needed for our interface to ACIS. Blends, shells, chamfers, etc all fail on curves that are not G1 continuous. You would need to make each discontinuity a new curve.
#3 Posted : Tuesday, April 3, 2007 3:57:44 PM(UTC)
Hi Brian,
It is one of the reasons why we treat each segment as a curve (and then group) for imported Illustrator data.
mugu
#4 Posted : Tuesday, June 26, 2007 1:11:48 AM(UTC)
mugu
I'm new to viacad and was exploring the surfacing features. How do I stitch separate surfaces together or convert to a solid? And are there any third party plugins or resources for viacad? So far I really enjoy viacad but need some sort of advance turorial for your surfacing features. Thx.
#5 Posted : Tuesday, June 26, 2007 9:49:56 AM(UTC)
Use the Stitch tool which is located under the blend/chamfer tools and above the advanced transform tools. Select your surfaces and if they are closed, will form a solid. The surfaces act as a parent to the solid. If you have curves defining the surfaces, they act as parent to the surfaces. Changing a parent will update the child. It is aok to add features to the stitched solid, they will update as well when a parent is changed. (However, the volume must remain closed as you modify)
