Suggestions
Disable Message Trim Del Entire Object Options (#2180)
Tim Please, add an option to disable the error message "Trimming will delete entrie object. Thanks Jason
Originally Posted by: jdi000 Tim Please, add an option to disable the error message "Trimming will delete entrie object. Thanks Jason
Hey Jason!
Every time I get that message...its actually true:D. Do you get instrances when it doesnt actually do just that ?
Originally Posted by: unique Hey Jason! Every time I get that message...its actually true:D. Do you get instrances when it doesnt actually do just that ?
Hi Paul
It seems to work fine, only shows message when its actually removing object, its just the message is redundant when you are trimming objects alot of times you are getting rid of objects there is no message when you delete an object, so it would be nice to be able to disable that message it takes time to acknowledge the message everytime.
Originally Posted by: jdi000 Hi Paul It seems to work fine, only shows message when its actually removing object, its just the message is redundant when you are trimming objects alot of times you are getting rid of objects there is no message when you delete an object, so it would be nice to be able to disable that message it takes time to acknowledge the message everytime. Jason
Hi Jason - I agree in principal. You should show an avi in an instance where you feel the message should not show...then the powers that be can understand what you mean and implement if poss....
Good luck:cool:
>>Please, add an option to disable the error >>message "Trimming will delete entrie object. Got it into FX V6. It now has a check box to not show the dialog box again. Tim
Suggestions
