Tips and Tutorials
Modifying 3D Solids tutorial (#3387)
As a new user of ViaCAD 2D/3D v7 I have been working through the supplied tutorials over the last few weeks. All has gone well until I got to trimming solids in the Modifying 3D solids tutorial where I can't replicate what is shown in either the video or step by step lessons. Trimming the solid with the curve should remove the rear of the block, all I can achieve is to cut a curved slot through the block...
No doubt I have misunderstood something but what? Where I am right now the learning curve is so steep I am in danger of falling off so any help would be appreciated.
beejay99 attached the following image(s):
(12kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi
I believe what you are doing is right as I get the same result you do when using the trim solid tool in version 7 of the program...
However its seems as if the trim solid tools is not behaving as it did back in version 5 or version 6... The trim solid tool in version 5 and version 6 behaves as the tutorial but 7 only seem to behave as a boolean tool not a trim tool, it is only trimming the intersecting parts.
Can anyone else confirm these results? please?
The video I attached is version 5 that split the solid as the tutorial , then if you press ctrl key it toggles the part of the trim solid that is retained it goes from left side to intersection only then to right side
splitsolidv5.zip
(537kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Could this be because ACIS has been updated Tim ?
Originally Posted by: jdi000 Hi I believe what you are doing is right as I get the same result you do when using the trim solid tool in version 7 of the program... However its seems as if the trim solid tools is not behaving as it did back in version 5 or version 6... The trim solid tool in version 5 and version 6 behaves as the tutorial but 7 only seem to behave as a boolean tool not a trim tool, it is only trimming the intersecting parts. Can anyone else confirm these results? please? The video I attached is version 5 that split the solid as the tutorial , then if you press ctrl key it toggles the part of the trim solid that is retained it goes from left side to intersection only then to right side Regards Jason
This is what I get.
If you use a curve as a cutting tool in beta 949, it does trim the part in the way shown in the help widget, except I think it trims the opposite side to that indicated by the direction of the arrows.
Using a solid as a cutting tool just removes the intersection, leaving 1 part in several disconnected pieces that have to be separated by doing a Change Object Type... to Solids and then deleting the correct piece.
Martin.
Earlier today I wrote:
Originally Posted by: beejay99 As a new user of ViaCAD 2D/3D v7 I have been working through the supplied tutorials over the last few weeks. All has gone well until I got to trimming solids in the Modifying 3D solids tutorial where I can't replicate what is shown in either the video or step by step lessons. Trimming the solid with the curve should remove the rear of the block, all I can achieve is to cut a curved slot through the block... No doubt I have misunderstood something but what? Where I am right now the learning curve is so steep I am in danger of falling off so any help would be appreciated. Thanks
In a very short time there have been several replies here which have reassured me as to my sanity and for which I am very grateful. Thanks again.
Yes, I will back you up on that, jdi000. I've been seeing that too.
Found it. There was a difference in an low level ACIS procedure that is now accounted for. Fixed in 950. Tim
Tips and Tutorials
