Hi Tim I am trying to do a simple animation movie of walk around (fly by) an object that I have designed. I drew an eliptical path around the object, select the fly by icon, slect the path and select a point on the object. I click OK for the ensuing menus to save the movie. A preview window pops up and shows some images of the movie being rendered. But at the end of it, the movie file is no where to be found. It is completely NOT saved. Please advise. Thanks. Alex Macbook Pro, OS10.5, Shark FX 750
Hi Alexander Just tried it here .. (Mac) .. and no problem Can somebody else please try it on a PC .. See if we can work out the problem
Hi Jol Thanks for trying. I tried it with several different files but still can't get the Fly-By Animation to save. I can only save a clip using Object VR. Best regards Alex
Come on guys - can we please have somebody with a PC check this function for Alexander !! It appears to work fine on the mac In the meantime Alexander - can you try it just with a cube .. perhaps then we can see if it's related to your geometry
Thanks: 172 times Was thanked: 158 time(s) in 108 post(s)
Hi Jol, Alex's signature indicates that the Mac is being used. Larry
Bugger - thanks Larry ! OK - can you get a build later than 750 ?
Hi Guys Thanks for trying. I tried again today, and I found that if I saved the file on the Desktop, instead of a specific work folder, the animation saves! So maybe it is something to do with Shark on Mac. My folder is not locked (I've checked). By the way, how do I get any Shark builds higher than 750? When I check for the latest version, it always tells me that I already have the latest in 750. Thanks again. Best regards Alex
Hi Alex,
Originally Posted by: Alexander By the way, how do I get any Shark builds higher than 750?
The latest build is 838:-
http://forum.punchcad.com/showthread.php?t=2423 - Steve
