3D View Toggle option (#3982)
Hi, At the bottom on the left where you toggle between wire frame and 3d solid view, if you choose the 3D solid view, I see the object in 3d, solid but with the lines highlighted. If I use the grabber, while I drag it, the lines disappear and I get the 3D view without lines. Can I toggle between with lines and without lines in the 3d Solid view?
hmm..... Alternative 1: Hit Ctrl-T (or View - Shade Now) to make the lines go away for a moment. Alternative 2: Go to View - Shade Options... and change the Static Shade to something without edges. This will be full-time without lines/edges. Have fun there... bye
Hi Johan You might want to see what your dynamic display setting is at. This is the display mode for dynamic pan, rotates etc and is located under the View:Shade Options dialog box. Tim
