jors
#1 Posted : Monday, September 26, 2011 12:34:16 PM(UTC)
jors
At the bottom on the left where you toggle between wire frame and 3d solid view, if you choose the 3D solid view, I see the object in 3d, solid but with the lines highlighted.
If I use the grabber, while I drag it, the lines disappear and I get the 3D view without lines.
Can I toggle between with lines and without lines in the 3d Solid view?
phil
#2 Posted : Monday, September 26, 2011 2:02:39 PM(UTC)
phil
hmm.....
Alternative 1: Hit Ctrl-T (or View - Shade Now) to make the lines go away for a moment.
Alternative 2: Go to View - Shade Options... and change the Static Shade to something without edges. This will be full-time without lines/edges.
Have fun there...
bye
#3 Posted : Friday, September 30, 2011 2:40:48 PM(UTC)
Hi Johan
You might want to see what your dynamic display setting is at. This is the display mode for dynamic pan, rotates etc and is located under the View:Shade Options dialog box.
