jasonb
#1 Posted : Thursday, April 26, 2007 8:52:33 AM(UTC)
jasonb
Is there any way of setting the default view when opening up CU? The default view is set to top view. Is there any way of configuring CU to display the side view or Isometric when starting up as a default?
#2 Posted : Saturday, April 28, 2007 3:11:57 PM(UTC)
You can use a startup.dat file.
1. Launch CU.
2. Set view or create new one. Set zoom also.
3. Optionally create layers, custom pen styles etc.
4. File:Save As: startup.dat
Save this file to the application folder. When CU launches, it looks for this file and will preload it.
