Import/Export
Photoshop CS3 File format (#191)
Does CU export a file format that Photoshop CS3 Extended will accept? I've not had any luck getting a file format that will open.
jasonb wrote: Does CU export a file format that Photoshop CS3 Extended will accept? I've not had any luck getting a file format that will open.
Hi Jason,
I don't believe so.
Hopefully something to consider for V5 release. I would like to see the ability to export a object as a Alias/Wavefront OBJ in the future. Also the ability to edit the object's texture within CS3 would be a great. Since I work from Illustrator to CU, It would be nice to take my object from CU and integrate with a Photoshop document. It would be a great addition to my workflow. Something to consider!?
It looks like Photoshop CS3 will read a OBJ file. One more reason to get this into the next release.
Shark FX 9 build 1143
OS X 9.5
matter.cc
Import/Export
