Rendering & Display
Weird Render to File Options (#1677)
When I tried to do a Render-to-file, the options menu went crazy and showed weird options instead of the expected Shadows ON/OFF and Anti Alias options (see pix).
:confused:
Seems like text from elseware in the program got mixed into the menu. Weird!
Alexander Lau
Mac OSX 10.4.11, Shark FX (build 750)
Alexander attached the following image(s):
(58kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hello Alexander Looks like you have a build where the strings file is either incorrect or corrupted. Try download and re-installing the application again. If this does not correct the issue then you will need to contact your reseller for further assistance. All the best Nick
Hi Nick Thanks for the tip. I will try. The strange thing is that it doesn't happen all the time. Today, when I opened the same file, the options are all OK. Best regards Alex
Happens to me about once a month. Art Macintel shark
Originally Posted by: Art Happens to me about once a month. Art Macintel shark
We found the steps to repeat and fixed.
Rendering & Display
