Rendering & Display
Display while rotate/turning object (#4633)
I use ViaCad V7. I still wonder why the display of an object while rotating/turning (by Click$Drag of the wheelbutton of the mouse) the display of the object temporarely changes from "Display with shade" to "Display hidden lines" (only the visible lines). Stopping the rotating/turning, it takes 1-2 seconds, and the display object will return to the "Display with shade". This is also the case using the 3DConnexion-device. I thought that this choice was made in the program to reduce computing time, so I did not bother. But is it normal?
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
You can change the display preferences by double click on display style icon or view/shade options menu
Thanks for the rapid reaction on the edge of the new year. By double clicking on the dispay-icon, I could chose the right option. Now it works fine. Again thanks.
Rendering & Display
