bradcan
#1 Posted : Wednesday, August 13, 2008 7:03:39 AM(UTC)
bradcan
What does 'Valid hatch region not found' mean?
If I scale the profile x10 it hatches fine, also I can extrude it so there ain't no gaps!
If I hatch an area and progressively scale it down there comes a size that leaves the hatch un-scaled. Strangely, there seems to be some kind of limiting width. However, there appears to be no lower limit to the height of a region that will hatch successfully.
Very odd any clues?
hatch.vc3 (12kb) downloaded 4 time(s).
#2 Posted : Thursday, August 14, 2008 10:51:47 AM(UTC)
Very odd any clues?
Repeated found and fixed in build 797. You can use the Pen:Cross Hatch tool on this profile until the build is available.
Thanks for the bug report,
blowlamp
#3 Posted : Wednesday, September 3, 2008 11:51:02 AM(UTC)
blowlamp
Same error shows in the above file and also within rectangles, unless you change the Object Type to lines.
PC XP and ViaCad 804.
Cheers, Martin.
