Thanks: 224 times Was thanked: 177 time(s) in 107 post(s)
Did I say before I hate the dimensions settings ?
Every time I change scale (from nano-science to house building), it takes me 20 minutes to get it back correct (text, arrows, line parameters, offsets...).
Today, I'm reaching the limit : by fiddling the stuff by usual trial ans errors method, I lost all the dimension text.
It turned "###" (see picture).
Any hope to see this improved ?
JL
(53kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
I remember there being a text file that one could modify so that your dimension settings could be configured as the default. I think the there is a file in Environ Folder called SysDimen.ini. I believe that this can be modified in Apple's TextEdit or the MS's NotePad. Good Luck!
>> Did I say before I hate the dimensions settings ? : )
Also for CU 5 .. .. do we have text size, font and style showing up in the attributes of the Edit Object Box ?
But Pro/E is so fun that way! ; )
good 2D drawing is a current weakness in Concepts. I hope to see this addressed in next version. I think Tim said there were looking at it. Weaknesses fall in 3 main areas for me. 1. settings don't stick 2. some settings are not customizable (default pen styles) 3. custom pen styles can not be assigned a short cut key Simply put: a. I want to be able to set the line style as I like them b. I want to be able to select them quickly with a short cut key c. I want to know I am going to get predictable results when changing scales, views and files. Achieve that and Concepts will be a very special tool that I can work in from concept to production drawings. Gary
