#1 Posted : Sunday, March 4, 2007 12:45:10 PM(UTC)
Was thanked: 171 time(s) in 103 post(s)
I had two files opened at the same time.
After some time and playing with other softs, I saved the first file and closed it - OK
When the second file appeared on the screen, all the CU menus had gone except "file".
Same as if there was no file open.
----> Impossible to save or even to close.
See on the screenshot attached.
Quit is the only way out.
I'm lucky I didn't do too much work on that one...
JL
The attachment size limit for PNG is really too small!
Image 10.jpg (28kb) downloaded 6 time(s).
ALBANO
#2 Posted : Monday, March 5, 2007 3:30:15 AM(UTC)
ALBANO
Was thanked: 28 time(s) in 15 post(s)
jlm wrote:
Have a similar problem here under OSX 10.4.8 on MacPro.
Safari will highjack my CU-menue-bar and the keyboard when switching to it.
Only way to get back control is klicking on the CU icon in the dock. Klicking on a CU-window wont do it.
ALBAN
