Thanks: 209 times Was thanked: 150 time(s) in 95 post(s)
Every visit to the site, I have to log in again.
Tim, in thy orisons, be all my sins remembered!
(7kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Yep, same here. Would be nice to have this working. Thanks.
I tried it on both Mac and PC with no luck. Must be a forum cookie problem. While I'm at it... the avatar option in the user CP is not working as it should.
Brian Graham Mac OS Ventura 13.6.3 Mac mini Apple M1 16GB 1TB SSD Shark FXv 14 Build 1641
I just was about to post the same complaint. Needs to be fixed soon! Ciao, Norbert
Thanks: 26 times Was thanked: 5 time(s) in 2 post(s)
How hard can this be. please, just set the cookie. Or are they trying to get us to all go away by not only moving to an even uglier looking interface and making log in a continuous pain in the you know what ?
Shark FX 9 build 1143
OS X 9.5
matter.cc
I can't find a setting anywhere for it in the admin panel. Still looking.. Tim Olson Punch! Software
Thanks: 23 times Was thanked: 49 time(s) in 36 post(s)
works fine here under XPproSP2 w/ MS IE 6.0 (internet zone), thus probably a security setting of the used browser? Adding the domain to the trusted zone might be helpful for avoiding this. Norbert Grund
It appears to be Safari. It seems to work with Firefox. Patrick
API wrote: It appears to be Safari.
Safari is known to be problematic in connection with JavaScripts, does maybe have an influence on that.
Norbert Grund
Every time I come to the forum, until I log in, all the forums appear to be empty (it says there are no posts on any of them). [I'm on an Intel Mac using Firefox.] It's got to be seen as a sales issue. When I check out new software, I go to the forums to see what issues people are dealing with. If the forums are empty (as they appear to be here), it looks like the app is dead.
As reported earlier, I've switched to CAMINO for browsing the PunchCAD forums. Seems to work fine. Why Safari is having a problem I'm not sure. I'll report the site to Apple today. If we all do (Safari users that is) perhaps Apple will fix the issue.
KurtF wrote: As reported earlier, I've switched to CAMINO for browsing the PunchCAD forums. Seems to work fine. Why Safari is having a problem I'm not sure. I'll report the site to Apple today. If we all do (Safari users that is) perhaps Apple will fix the issue.
Yeah, same problem here... rather odd, I've never had a problem with any other forums and safari before.
