Thanks: 224 times Was thanked: 176 time(s) in 107 post(s)
Make a new box text Type text Select all text Change text size in objText menu... --->It doesn't work! I need to deselect tool and select back again. JL
The text it self is not recognized until you are out of the text input process. You will notice that the text does not turn the "Selection" red color until you click outside the Text Box. Ergo you must click outside the text box to edit the text. However, you do not need to deselect the tool.
Todd Q CAD Support Specialist Encore Software/ IMSI Design
Todd .. changing the size of a text box is less than optimal .. you need to turn the points on - you get 2 - then you need to move one of them The mental association with a box isi lost Why not have the box reappear when it's selected .. that way you know it's box text - and you know instinctively how to edit it's size ?
I have already added this to the feature request list.
