#1 Posted : Monday, May 7, 2007 7:47:29 AM(UTC)
Arcs have only one end point visible (+ center).
Is there a reason for that ?
I'd like to see both end points.
JL
#2 Posted : Monday, May 7, 2007 1:25:33 PM(UTC)
I can see both JL .. what are the circumstances ?
#3 Posted : Tuesday, May 8, 2007 12:13:08 AM(UTC)
My post was lacking precision :
Actually, I was trying to modify an old CU file (created in Nov 2004 with the latest CU version available at that time) and I realized that all the arcs were behaving in a very strange way.
I reported the following arc bugs to Todd yesterday :
- Only one endpoint showing
- Start angle always "0" in info dialog, even when it's not.
- Impossible to change the angles values (goes anywhere)
- Impossible to corner trim (either cuts too far, or disappears)
There must have been a mistake in one of the file format upgrade.
Todd could confirm these points and I'm sure he will fix with the help of Tim.
JL
#4 Posted : Saturday, May 12, 2007 4:33:01 AM(UTC)
Here's the file:
(a file created less than 3 years ago should'nt get corrupted just by software upgrade:( )
Corner trim bug.cu (8kb) downloaded 6 time(s).
#5 Posted : Sunday, May 13, 2007 10:19:00 PM(UTC)
JL
We support a variety of arc definitions. This arc is defined as a center, starting point, and angle. When we do a show points, we only show the points needed for the specific definition. Various arc defintions include:
--center, start point, angle
--three points on
--start, end, middle
--center, start point, end point
etc
#6 Posted : Monday, May 14, 2007 1:13:18 AM(UTC)
JL
Thanks Tim,
Point#1 : OK, I understand your answer.
--> Don't you think the info dialog should tell the type of arc ?
point#2 : then, "0" means "relative start" and not absolute angle for this type of arc.
--> Isn't it confusing ?
Points #3 & 4 are still looking buggy.
JL
Guest (6)
