#1 Posted : Friday, June 22, 2007 3:10:04 AM(UTC)
Was thanked: 173 time(s) in 105 post(s)
IGS export is working better than ever : CU solids and surfaces are usually perfectly received by our customers / suppliers.
Though there are a few bugs with geometry.
Bug #1 : on attached file
- Select all and export IGS,
- New file and import the same,
---> You see correct surface and solid, and reduced geometry far away from correct place.
---> It is obviously a reduction factor of 25,4 applied to geometry only (Inches strike again !)
Bug #2 : on same file
- Select solids and surface only and export IGS, with "selected only",
---> The unwanted geometry is still here (small & far away)...
Regards,
JL
(Sorry, I forgot that Punch forum is the only place where I cannot upload anything with a Freebox modem - I'll send it by mail).
posh.de
#2 Posted : Friday, June 22, 2007 4:21:51 AM(UTC)
posh.de
jlm wrote:
(Sorry, I forgot that Punch forum is the only place where I cannot upload anything with a Freebox modem).
cannot imagine that the forum software is capable to detect or interested in knowing the used internet access hardware of a user.. more likely a configured limitation in the area of file format (extension) or file size.
Norbert
#3 Posted : Friday, June 22, 2007 12:09:15 PM(UTC)
Norbert,
I know it's strange, but when I remove the freebox and plug an older modem, the same file is uploaded quick & fast.
This is what I'm doing right now to attach the files.
I never met this issue on other forums.
Regards,
JL
Bug IGS.cu.zip (77kb) downloaded 5 time(s).
Bug IGS.igs.zip (26kb) downloaded 5 time(s).
posh.de
#4 Posted : Monday, June 25, 2007 4:00:17 AM(UTC)
posh.de
jlm wrote:
I know it's strange...
spooky, has maybe something to do with the web server Punch! is using in connection with the NAT/port forwarding/open ports etc. of your modem/router...
anyway, get a Lancom or Zyxel or Draytek if you wanna have a working network hardware (OT).
Norbert
