Thanks: 224 times Was thanked: 175 time(s) in 106 post(s)
May I ask a question ?
What does it mean ?
JL
(20kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Yep - that's still stupid !
Perhaps this is some debugging thing that has never been removed properly?
The numbers are not adding up, will look into. Tim
Simplifying six things to zero sounds like it's doing great justice to its name!
It's saying there are six faces, 3 are NURBS 3 are analytics. It was unable to simplify any of the three NURBS. But its a bit confusing how it is presented. Tim
More complexity about "simplify" :
I open an "old" sfx file of 108.7 Mb size and save it with last version (b823).
It comes down to 41.4 Mb...Fine !
Now, if I select everyting, remove links, simplify object and save again :
1 - I get the stupid message (attached)
2 - It is impossible to save, unless I change something else.
3 - The result file is slightly bigger 42.7 Mb...
- Is it really simplified ?
JL
(28kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Yes please Tim - you did say you'd review this. It's was too ambiguous .. and this is not the ambiguity popup
JL .. are you saying that I can open my old files and resave them to save half my hard disk ? I tried this and saved almost nothing. If I remove links and then simplify, I can get 114 Mb down to 42 Mb - but then my file is less useful
Originally Posted by: jol JL .. are you saying that I can open my old files and resave them to save half my hard disk ?
Yes Jol, some of the files are dramatically reduced by a "save as".
I don't know why.
Maybe they had been saved in the past with "display list" on in prefs...
I switched this off on my main desktop, but my files are sometimes opened and saved on other computers...
Or maybe it's just a good performance from the most recent ACIS ???
JL
>>JL .. are you saying that I can open my old files and resave them to save >>half my hard disk ? It may be JL had some delete pending objects in his file. When you delete stuff they dont actually get purged from the file until you save the file, read it back in, then save again. This is driven by Undo. In Shark V6, we've got some new features regarding this. Tim
Thanks Tim, Any news about the "simplify" ?
