Imported picture bugs (#954)
Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
It is very convenient to have an imported bmp image (logo for instance). Though, it seems that this feature hasn't been fine-tuned : --> it is still impossible to select with a clic (only fencing). --> There in no data in the Object info except "scale with view" box (which isn't an info but a display feature). --> Format & size would be welcome. --> What do the attributes mean for a picture (color & resolution) ? It doesn' seem to work. --> The image display is totally buggy on a 24" imac (the picture disappears soon after import), and OK on a MacPro (30" + Radeon X1900). JL
--> it is still impossible to select with a clic (only fencing). I implemented images to only select when boundaries are picked. I did this because I was thinking images would frequently be used to trace over. I thought it would be very annoying to have ambity box come up every time a user picked something when tracing. --> There in no data in the Object info except "scale with view" box (which isn't an info but a display feature). --> Format & size would be welcome. What do you mean by format? --> What do the attributes mean for a picture (color & resolution) ? It doesn' seem to work. yes, these really dont apply to images. images are displayed as they are imported. --> The image display is totally buggy on a 24" imac (the picture disappears soon after import), and OK on a MacPro (30" + Radeon X1900). Can you send me the image you are importing, I have a imac at home I can test on. Thanks for the feedback! Tim
Thanks Tim,
Here's an image.
(116kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
