2D Drafting
Phong display in sheet view - bug (#953)
Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
This is an old bug back on screen : In a sheet, change one of the views to "phong" (ie a simple sphere). Then zoom... --->The phong object is squeezed like an orange at the screen corner. But no juice comes out...
Yes, I've noticed this too. Very strange. :confused:
Actually, same bug with anu rendered view : phong, Gouraud, flat.
Attached screen capture is a model to sheet of a SPHERE:eek: .
JL
(14kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
The bug is still here ... JL
Still squeezing my spheres !
On V7, This bug is extremely easy to reproduce. I don't understand why it's still here. My spheres are almost totally squeezed...
hello, same problem for me Antoine
Strange...NOT HERE!!
Jean-Francois Jacques attached the following image(s):
(50kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
JL - were you on the first generation of 30" screens ?
JOL If you question is for me... I bought my 30" at the end of 2006 it's a LCD Apple ED Cinema HD (aluminum) DVI
Thanks JF (that'd be my new special name for you Jean-Francois !) Oh Lordie - sounds most like a graphics card glitch to me ! I think JL, TT and Antoine need to get together here - do you all have the same graphics adapter ? What else is common in your set-up ? I've certainly never seen it - but I really feel for JL as this has literally been bugging him for years ! JL - presumably you don't see this error on your laptop too ?
No Jol, it does'n seem to be related to the graphic board.
Here's a screengrab from my MacBook Pro : same bug.
The same thing too on my 24" iMac.
Jean-Francois, you show the model to sheet "at rest", did you try to zoom in ?
JL
(51kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Yes it's true..with zoom in, etc. Also with the typo in my template. It's very difficult to do a good CAD Sheet template. What you see it's not what you print!!
http://screencast.com/t/MGM4NTBj METEORE DESIGN / KEKO Stand Jean-Francois Jacques, Industrial Designer SharkCad Pro V14 B1653 Platform macOS 14 Sonoma
More example, it's a serious problem Tim, I spend a lot of time to adjust my file template to have a good CAD template print. In my file, some typo is out of border to be nice on my print!???
(49kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Thanks Jean-Franois,
Your movies are very clear : exactly what I wanted to explain.
Of course the defects are looking much worse on a real model, see attached views.
1 : initial drawing
2 : after changing the render to phong,
---> all the dimensions get thick, and the background turns to grey / white
3 : after zooming, see the mess...
JL
(75kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Jean-Francois Jacques More example, it's a serious problem Tim, I spend a lot of time to adjust my file template to have a good CAD template print. In my file, some typo is out of border to be nice on my print!???
JF
Remember that your drawings scale ie text and line weight scales to the printed output if you have preserve annotation sizes checked.
Try locking your text or uncheck the preserve annotation sizes in the print dialog box and see if you text outcome is better...
Quote: More example, it's a serious problem Tim, I spend a lot of time to adjust my file template to have a good CAD template print. In my file, some typo is out of border to be nice on my print!???
same problem for me.
Antoine
2D Drafting
