This has been mentioned several time but may be worth a separate post :
The tool isn't working with small gaps between two lines.
Without warning !
It creates too many bad profiles.
Thanks to have a look
JL
Bug trim.sfx
(14kb) downloaded 5 time(s). jlm attached the following image(s):
(46kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Jean-Francois Jacques Only one condition OverLap. [/url]
Thanks for the video Jean Franois.
It's not so easy to elongate the lines when they are slightly angled (draft).
Another workaround is to do an inverted trim (with option key) to prolongate the short line.
It was working simple since vellum's time but the bug appeared with one of last year's updates...
JL
This is from the Help feature near the top of the screen.
Martin.
(24kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Blow, I forgot this one!! But this Corner Trim Option Tool doesn't work with the JL's File.!!! Tim, can you check this file?
JL Repeated and looking into! Tim
>>The tool isn't working with small gaps between two lines. JL Repeated found and fixed in 948. Many thanks for posting that example file! Tim
