#1 Posted : Sunday, March 14, 2010 8:38:27 AM(UTC)
Here's a small file with a simple profile (exported "selected only" from a larger file.
All the bugs listed below have been mentioned at least once on this forum.
-1 The small preview icon does not reflect what is actually in the file. It shows something that was not exported.
-2 Gosh! 60 empty layers that I didn't want to export. Trash, Trash...
-3 Try to lathe the profile around the green line. A dialog says "Curves not planar", which is wrong - They are!
-4 See that there is a small gap in the profile. Too small ! The trim corner tool doesn't work on small gaps..
-5 Bloody hell, once again I opened the exported file without closing the original one. When I closed it, I lost all the menus, all the tools, and my unsaved work.
I think I should have posted that on the Beta section...
JL
Bug trim.sfx (15kb) downloaded 0 time(s).
Capture d™©cran 2010-03-14 15.09.21.png (19kb) downloaded 0 time(s).
Capture d™©cran 2010-03-14 15.10.46.png (45kb) downloaded 0 time(s).
Capture d™©cran 2010-03-14 15.31.21.png (101kb) downloaded 0 time(s).
Capture d™©cran 2010-03-14 15.29.02.png (52kb) downloaded 0 time(s).
#2 Posted : Sunday, August 29, 2010 5:15:17 AM(UTC)
Hi !
Am I the only one ?
blowlamp
#3 Posted : Sunday, August 29, 2010 7:15:00 AM(UTC)
blowlamp
Originally Posted by: jlm Go to Quoted Post
JL
Hi jlm.
1/ Agreed that it doesn't seem to show what appears when loaded. Is it something from one of the other layers?
2/ Have you tried the Compact... option, under Menu->Edit?
3/ That message is a bit obscure, but it does Lathe OK once you've filled the gap in the profile.
4/ That's true, it repeated for me too. You could use the Apparent Intersection Snap, for now.
5/ I couldn't try that as I'm only running the Demo version.
Martin.
