#1 Posted : Tuesday, October 30, 2012 6:58:04 AM(UTC)
Was thanked: 177 time(s) in 107 post(s)
When I export and re-import the surface on the left, it gets deformed (on the right).
Bug export surface.sfx (165kb) downloaded 5 time(s).
Bug export surface.stp.zip (5kb) downloaded 6 time(s).
Capture d™©cran 2012-10-30 13.11.01.png (55kb) downloaded 0 time(s).
rockyroad_us
#2 Posted : Tuesday, October 30, 2012 9:01:06 PM(UTC)
rockyroad_us
I can't produce it. What's your system's configuration. See mines below.
#3 Posted : Wednesday, October 31, 2012 3:21:23 AM(UTC)
Today : SFX 1015 - Macbook pro 2.5 GHz Intel Core 2 Duo.
I don't think it's linked to the configuration. This kind of things happens on any of my computers...
Did you try to import my step file ?
JL
la mouche
#4 Posted : Wednesday, October 31, 2012 3:28:26 AM(UTC)
la mouche
after import your step in my SharkFX.
Capture d™©cran 2012-10-31 10.27.19.png (31kb) downloaded 0 time(s).
blowlamp
#5 Posted : Wednesday, October 31, 2012 3:42:10 AM(UTC)
blowlamp
JL.
Just so you don't think you're cracking up. I can confirm that I got the same thing as you when I tried your file yesterday...
...but today, it won't repeat :confused:
Martin.
blowlamp
#6 Posted : Wednesday, October 31, 2012 3:49:43 AM(UTC)
blowlamp
Hang on - possible solution :)
When you Import this file, make sure you uncheck the Stitch Surfaces Into Solid option.
On the other hand, if you Open the file, then it seems like ViaCAD/Shark does the the above automatically and you don't get the distortion.
Martin.
rockyroad_us
#7 Posted : Wednesday, October 31, 2012 7:25:12 AM(UTC)
rockyroad_us
First of all, the step file you posted appears to have two surfaces. You can see them when imported unstitched with different colors.
When stitched checked, the two surfaces tend to combine thus you get that distortion.
#8 Posted : Thursday, November 1, 2012 9:17:03 AM(UTC)
Thanks Martin, Thanks Rocky !
It must be the tolerance when stitching...
Tim ?
