#1 Posted : Saturday, September 17, 2011 1:03:17 PM(UTC)
Select a solid and "verify > properties"
Selecting a material from the menu is OK.
If I change the density to whatever value, the mass is multiplied by 1000 !
It maybe due to a limited knowledge of metric units over there...:D
Capture d™©cran 2011-09-17 20.50.23.png (40kb) downloaded 5 time(s).
Capture d™©cran 2011-09-17 20.48.39.png (43kb) downloaded 5 time(s).
#2 Posted : Monday, September 19, 2011 4:16:39 PM(UTC)
JL,
Fixed in 992.
#3 Posted : Wednesday, September 21, 2011 5:51:17 PM(UTC)
Whoa... I never noticed that. I may need that patch.
dnns
#4 Posted : Friday, September 23, 2011 7:39:18 AM(UTC)
dnns
do your screen shots illustrate that somehow? If so, I'm missing how. The numbers all look right in what you've got posted.
#5 Posted : Sunday, September 25, 2011 6:23:57 PM(UTC)
Was that an error in Shark only? Maybe in the units
file?
I actually don't seem to have that problem, but, i'm using vcp 7.0, build 9671.
I searched the internet, found:
http://hypertextbook.com/facts/2004/KarenSutherland.shtml
and thought I would locate the same error. But, after seeing the 3rd table, my install and version sem to be okay.
#6 Posted : Sunday, September 25, 2011 6:46:58 PM(UTC)
In my instal, I checked in two ways. In the first, I selected a huge solid I created and it returned a volume and metric and imperial tonnage I know is quite close to what I arived at by hand in the past.
To make sure my copy/install is okay, I created a sphere of .01515m diameter, selected it, then noted the vol, wt, and density. I entered "1" in the density box before and after changing the units to use grams. After that, I changed the units back to kg, entered 0.00722, and the wt returned to 0.01308 kg.
If i'm missing something,let me know, please.
#7 Posted : Monday, September 26, 2011 3:47:43 AM(UTC)
Hi Zero,
Just as a reminder :
1 cm3 with density 1 weight 1 g
This is how it should be in metric...
Why do you have to use figures as 0.00722 and 0.01308 ?
:p
#8 Posted : Wednesday, September 28, 2011 8:49:04 PM(UTC)
Ot sure anymore. I think I was attempting to "object-match" or something.
#9 Posted : Sunday, October 16, 2011 9:16:10 AM(UTC)
The problem is back on with b994 !
#10 Posted : Wednesday, October 12, 2016 8:16:21 AM(UTC)
Originally Posted by: jlm Go to Quoted Post
Hi,Select a solid and "verify > properties"Selecting a material from the menu is OK.If I change the density to whatever value, the mass is multiplied by 1000 !It maybe due to a limited knowledge of metric units over there...:D
5 years later, this problem is still on...
I mean : if I type density 2.5 in the box, it's changed immediately in 2500.00
Edited by user Wednesday, October 12, 2016 8:19:12 AM(UTC)  | Reason: Not specified
Capture d’écran 2016-10-12 à 16.08.26.png (144kb) downloaded 5 time(s).
horst.w
#11 Posted : Wednesday, October 12, 2016 1:11:11 PM(UTC)
horst.w
Hi JLM,
in the property-windows is given as standard "kg / mm³"; that is a sureal value.
Checking the box " Use grams ", the calculation is ok, when for example water will be given with the right value 0.000,001 kg / mm³ then apears gr / mm³.
.... but you are right. depending from the scale there is an issue with the factor 1.000
The scale kg/mm³ is the value 0.000.001 for water.
Edited by user Thursday, October 13, 2016 12:00:33 AM(UTC)  | Reason: Not specified
