#1 Posted : Sunday, February 5, 2012 6:25:29 AM(UTC)
Hi
Has anybody got a simple trick to generate a mechanical gear ?
I mean a real involute spline.
Google told me there is a gear generator in SW, in Sketchup and others.
Can I have nice Shark teeth ?
JL
rockyroad_us
#2 Posted : Sunday, February 5, 2012 10:02:50 AM(UTC)
rockyroad_us
There's a gear generator I came across for $29 dollars but I believe is for PC only. Nice one to use as it has a lot of variables to play with.
I usually just go to a web site that sells gears and download their .sat or .step file for it and not worry about drawing that thing from scratch. You can just use the cad software to resize it. Be sure you have the same pitch on both gears.
blowlamp
#3 Posted : Sunday, February 5, 2012 10:36:35 AM(UTC)
blowlamp
Have a look here: http://www.gearotic.com/
I think it can produce a dxf file from any gear that you design within it.
Martin.
zumer
#4 Posted : Sunday, February 5, 2012 6:10:50 PM(UTC)
zumer
.spl lawspline script import should be able to produce the flank involute parametrically.
#5 Posted : Monday, February 6, 2012 12:52:21 AM(UTC)
Thanks Rockyroad,
Yes PC only...
I need to draw from scratch : it's special shape and plastic injection...
#6 Posted : Monday, February 6, 2012 12:54:14 AM(UTC)
Thanks Martin,
Interesting site, but PC only soft, apparently.
#7 Posted : Monday, February 6, 2012 12:57:14 AM(UTC)
Thanks Zumer,
I forgot about that !
It was included in Concept Unlimited tutorial, with a demo from Tim.
I'll try...
billbedford
#8 Posted : Monday, February 6, 2012 3:15:52 AM(UTC)
billbedford
I use [URL="http://www.openscad.org/"]OpenScad[/URL] and this [URL="http://www.thingiverse.com/thing:3575"]script[/URL] to produce my gears
