Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
                Hi
Has anybody got a simple trick to generate a mechanical gear ?
I mean a real involute spline.
Google told me there is a gear generator in SW, in Sketchup and others.
Can I have nice Shark teeth ?
JL
(285kb) downloaded 7  time(s). You cannot  view/download attachments. Try to login or register.
                There's a gear generator I came across for $29 dollars but I believe is for PC only.  Nice one to use as it has a lot of variables to play with. I usually just go to a web site that sells gears and download their .sat or .step file for it and not worry about drawing that thing from scratch.  You can just use the cad software to resize it.  Be sure you have the same pitch on both gears.
                Have a look here:
http://www.gearotic.com/ I think it can produce a dxf file from any gear that you design within it.
Martin.
                .spl lawspline script import should be able to produce the flank involute parametrically.
                Originally Posted by: rockyroad_us  There's a gear generator I came across for $29 dollars but I believe is for PC only.  Nice one to use as it has a lot of variables to play with. I usually just go to a web site that sells gears and download their .sat or .step file for it and not worry about drawing that thing from scratch.  You can just use the cad software to resize it.
Thanks Rockyroad,
Yes PC only...
I need to draw from scratch : it's special shape and plastic injection...
                Originally Posted by: blowlamp  Thanks Martin,
Interesting site, but PC only soft, apparently.
                Originally Posted by: zumer  .spl lawspline script import should be able to produce the flank involute parametrically.
Thanks Zumer,
I forgot about that !
It was included in Concept Unlimited tutorial, with a demo from Tim.
I'll try...
                I use [URL="http://www.openscad.org/"]OpenScad[/URL] and this [URL="http://www.thingiverse.com/thing:3575"]script[/URL] to produce my gears
