Filip
#1 Posted : Friday, September 20, 2013 1:12:02 PM(UTC)
Filip
Hi.
I have flat grid and wish to use on it Presure Deform to make it rounded like on attached file.
But I cannot do it, why?
I also tried Curve Deform but no good results.
Any ideas?
Filip
deform.slt (1,993kb) downloaded 5 time(s).
Filip attached the following image(s):
rockyroad_us
#2 Posted : Saturday, September 21, 2013 11:58:11 AM(UTC)
rockyroad_us
Might need to extrude it longer and split it with a surface that resembles that shape. I guess it depends how you would want the openings to look like. Either have the squares openings with straight edges or curved ones.
Also, where's your boarder?
Filip
#3 Posted : Saturday, September 21, 2013 2:58:41 PM(UTC)
Filip
Thanks for information and help.
So you also have not used Presure Deform. I just think it is impossible to use am I right? is it bug or just impossible to be done :confused:
I had used Blend once from x side once from y side and get result like from imagine above.
But truly I wanted to do it with Presure Deform.
I just put it on forum without boarder.
memphisjed
#4 Posted : Monday, September 23, 2013 2:42:42 AM(UTC)
memphisjed
Was thanked: 11 time(s) in 9 post(s)
That was a fun thinking game, or procrastination exercise.
draw flat projection, grid and ellipse.
extrude outer ellipse
deform top face with pressure
extrude inner ellipse and grill fairly tall
subtract cityscape from deformed shape (blue solid)-
now, to get the cool radials to normals
convert top face to surface
thicken this surface (silver solid)
Magic thru technology.
memphisjed attached the following image(s):
Jean-Francois Jacques
#5 Posted : Monday, September 23, 2013 5:34:47 AM(UTC)
Canada
maybe a video.....look interesting!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
rockyroad_us
#6 Posted : Monday, September 23, 2013 9:20:01 AM(UTC)
rockyroad_us
I think you need to work backwards to use pressure deform. It can't be done on the surface with the openings in place as your example. Software can't think right.
I think your best approach is to first use a cylinder and do pressure deform with shared faces tangent fixed or no tangency from the inspector if available as I'm doing this in sharkfx. after that you can just hollow it out, then subtract or cutout the solid to get the square openings.
Filip
#7 Posted : Monday, September 23, 2013 3:01:19 PM(UTC)
Filip
Thank you all for interested of subject.
Like I wrote previously we have made it by blend.
Bellow is video which show how it was made.
blend.zip (383kb) downloaded 6 time(s).
#8 Posted : Tuesday, September 24, 2013 3:51:35 PM(UTC)
Canada
Nice shot!
blowlamp
#9 Posted : Wednesday, September 25, 2013 3:25:37 AM(UTC)
blowlamp
This could be done quite easily by using the Rail Revolve Surface tool.
http://screencast.com/t/CdtQcl7Os
Martin.
#10 Posted : Wednesday, September 25, 2013 5:40:16 PM(UTC)
I got interesting and chaotic results by applying two bend along the curve at 90 one of each other, see pics and files, maybe the right combination keys can acquire the shape you want
Luis G.
[ATTACH]4761[/ATTACH]
[ATTACH]4762[/ATTACH]
[ATTACH]4763[/ATTACH]
[ATTACH]4764[/ATTACH]
[ATTACH]4765[/ATTACH]
benshk.sfx (723kb) downloaded 5 time(s).
benshk2.sfx (1,151kb) downloaded 5 time(s).
MacOSX Sonoma 14.7.1
#11 Posted : Wednesday, September 25, 2013 6:59:10 PM(UTC)
Ok, here is a better approach using combination of tools:
extrude the grid profile
bend along the curve two times, 90 degrees each arc (this produce a slightly deformed shape, not rounded
Cut solid with a line to get a flat surface of the bottom of the part
Offset top surface by 0
isolate that surfaces and make a thickness surface of it
Here the result
[ATTACH]4766[/ATTACH]
Filip
#12 Posted : Thursday, September 26, 2013 10:21:48 AM(UTC)
Filip
It looks great, Thanks for share.
Guest (11)
