bmeissner
#1 Posted : Saturday, September 4, 2010 11:49:37 AM(UTC)
bmeissner
Tim,
as far as I know the Granite import filter usually supports the Pro/E *.neu format (it does, e.g., in PolyTrans). Assuming the SharkFX import filter is based on the same licensed technology, why isn't this format supported in SFX?
In my experience, the *.neu format sometimes helps importing files which tend to fail as *.prt or *.asm.
Bernd
#2 Posted : Saturday, September 4, 2010 6:30:08 PM(UTC)
Hi Bernd
We're not using Granite to do the PRO/E translations but a reverse engineering solution from Spatial.
bmeissner
#3 Posted : Saturday, September 4, 2010 6:40:33 PM(UTC)
bmeissner
OK, that explains it, thanks. Maybe Spatial could hack the *.neu format, too? AFAIK it's a stripped down, simple version of the Pro/E format and is used to exchange Pro/E files between different versions of this application :)
Bernd
