Import/Export
SharkFX 5.5: File size/object number limits? (#2018)
                Hi all,
                ASICS is still 32-bit, so that might be the problem. Can you get the person who is supplying the STEP file to divide it into a few smaller groupings and then import those individually onto different layers so that not everything is active and visible ?
    Shark FX 9 build 1143
OS X 9.5
matter.cc
                Today I sent 7 crash logs to Tim.
My file was 85 Mb and it crashed at any memory demanding operation : boolean, trim, copy and paste...
Message (when any) was "Free store overflow..."
Before crashing, I could see display troubles when changing layers : some elements appearing in wireframe.
I think I know the file size limit now...
(My Macpro has 14 Gb memory)
JL
(16kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: NickB  ASICS is still 32-bit, so that might be the problem.
Well, obviously there is a 64-bit version of ACIS. Autodessys uses this with FormZ 64. Currently I've choosen the "client is to split large file" version, but anyway, I'd be interested in what SharkFX is able to handle, regarding file sizes, object numbers etc.
Bernd
                .. only 32 bit so far on the Mac according to Spatial docs
http://doc.spatial.com/r19/inde...32-bit_GNU_C.2B.2B_4.0.1
                And the 64-bit is still in development on the windows side.
OS X 9.5
matter.cc
Import/Export
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
