ianjkirby
#1 Posted : Wednesday, April 9, 2008 8:28:05 AM(UTC)
ianjkirby
Recently I have had a lot of difficulty trying to select edges for filleting two adjacent solids. The difficulty arises because partway through the selection process I need to rotate or translate the model to be able to "see" the next edge to select. When I choose the rotate or translate tools, the fillet tool and those selections already made disappear. Is there something I am missing here, or is it meant to work like that? A package I used in another life allowed me to zip off to the toolbar to select a translation or zoom tool, and when finished with it, the previous modelling tool was still current, as were any selections already made. Anyone care to comment?
Regards, Ian Kirby.
Wollongong NSW Australia
Ian Kirby
Wollongong Australia
nick
#2 Posted : Wednesday, April 9, 2008 9:58:53 AM(UTC)
nick
Hello Ian
Just use the scroll wheel of your mouse to rotate / zoom as required. This shouldn't effect your selections.
All the best
Nick
ianjkirby
#3 Posted : Thursday, April 10, 2008 3:19:42 PM(UTC)
ianjkirby
Thanks, Nick. What about if one NEEDS to translate/rotate an object in order to be able to make the next selection? Is there a way to do this without losing one's previously selected data?
Regards, Ian Kirby.
Ian Kirby
nick
#4 Posted : Thursday, April 10, 2008 3:27:45 PM(UTC)
nick
Hello Ian
Sorry but I must be missing your point, if you use the middle mouse button you can translate, rotate and zoom view whilst maintaining existing selections.
All the best
Nick
ianjkirby
#5 Posted : Sunday, April 13, 2008 7:02:11 AM(UTC)
ianjkirby
Thankyou Nick,
My fault! I don't have a mouse, and use the trackpad on my Macbook, which I have just learned how to drive (in Viacad). One needs to be a bit like a pianist, using several fingers, and several sides of one's brain, but I have made it work. Thanks for your patience.
Regards, Ian Kirby.
Ian Kirby
nick
#6 Posted : Sunday, April 13, 2008 10:24:58 AM(UTC)
nick
Hello Ian
No problem. I can't recommend a mouse with a wheel enough, they improve your productivity immensely.
All the best
Nick
Todd Quinlan
#7 Posted : Thursday, April 17, 2008 2:58:10 PM(UTC)
Todd Quinlan
Hello Ian
When you are using the fillet tool and you want to rotate or move the object to get a better view of your object, you do not want to use the rotate or translate tools. These tools will actually rotate or move the part. What you want to do is use the dynamic rotate tool to rotate your view of the part or the dynamic pan tool to move your view of the part. however, regardless of the tool you change to you will lose the existing tool you are currently using.
Nick is correct in recommending a wheel mouse. The wheel mouse allows you to use the dynamic rotate, dynamic pan and zoom in and out with out switching tools. Without one, you will need to take care in setting your view of the object in the proper angle before selecting the fillet tool, so that you can have access to the edges you need without moving the view after you select the fillet tool.
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
nick
#8 Posted : Friday, April 18, 2008 12:00:43 PM(UTC)
nick
Hello All
You can also change your display mode to wireframe to allow you to select an edge on the reverse side of an object, just make sure you keep the shift key held down if you do this whilst attempting to select multiple edges.
All the best
Nick
ianjkirby
#9 Posted : Friday, April 18, 2008 4:23:15 PM(UTC)
ianjkirby
Thanks Todd and Nick,
I understand the need to use dynamic views rather than model moves. It just took me a while to work out then remember to hold down the shift key through the dynamic viewing process!!
Regards, Ian Kirby.
Ian Kirby
#10 Posted : Saturday, April 19, 2008 2:27:33 PM(UTC)
Was thanked: 150 time(s) in 95 post(s)
Nick
You can also set the object display info to transparent.
I find it easier...
JL
