Alexander
#1 Posted : Monday, February 11, 2008 10:29:25 PM(UTC)
Alexander
In Shark FX (also happens sometimes in CU sp4), when you try to dimension an object with more than one decimal place and the dimension is a whole number, you cannot get the dimension to show up as more than one decimal place. For example, 10 mm should show as 10.00 if I select 2 decimal places with trailing zeros, but it always shows up as 10.0 in Shark FX. Is this a bug?
Alexander Lau
a N d studio
Singapore
Alexander attached the following image(s):
DIM Trailing Zeros.jpg (131kb) downloaded 5 time(s).
#2 Posted : Tuesday, February 12, 2008 12:40:51 AM(UTC)
Checking into...
#3 Posted : Wednesday, February 13, 2008 1:30:33 AM(UTC)
Alexander,
Ryan fixed today...
Alexander
#4 Posted : Wednesday, February 13, 2008 7:32:15 PM(UTC)
Alexander
Great news, Tim. Thanks for the quick response.
When can we expect to get the patch?
Best regards
Alexander Lau
a N d studio
